07-31-2015 06:44 AM
1. See that the E.164 number is written in its full form, including the countrycode IDDD. Example: +46-8-9761234 2. Remove all non-digit characters with the exception of the leading '+'. Example: +4689761234 3. Remove all characters with the exception of the digits. Example: 4689761234 4. Put dots (".") between each digit. Example: 4.6.8.9.7.6.1.2.3.4 5. Reverse the order of the digits. Example: 4.3.2.1.6.7.9.8.6.4 6. Append the string ".e164.arpa" to the end. Example: 4.3.2.1.6.7.9.8.6.4.e164.arpa
07-31-2015 11:15 AM
Are you sure you are in the right forum?
