You have two several options that you can use. First, although I am not sure which version of Lookout first supported this, you can use the TBAI, TBAO, TBDI and TBDO data members. If the fpoint.cbx in Lookout 4.0.1 does not support these members, you have two other options. If you are using ethernet modules you can connect directly to the ethernet module and access the channels. For more information on this approach please see the following (note: the article talks about datasockets but using Object Explorer provides the same hierarchy & URL's):
http://zone.ni.com/devzone/conceptd.nsf/webmain/A6617392B393C4B886256ACB0053AEBE?opendocument&node=DZ52425_US
Finally, you can use the FieldPoint OPC server with the Lookout OPC client to access the FP-TB-10 modules.
Regar
ds,
Aaron
