I am running Lookout 4.5 under WinNT 4 with a Opto22 compatible duTec Master I/O controller.
I've been working to convert a Lookout 3.8 program for use with 4.5 and hit a snag. I can get digital outputs to work, but I cannot get analog inputs to work.
To investigate further, I wrote a small program to read the analog input off a clean duTec, equipped only with an analog input. Doing this in Lookout 3.8, I can easily read the input voltage. Doing the same in 4.5, I cannot read the input voltage. If I equip the duTec with a digital output module, I have no trouble switching it on and off with 4.5.
Is there some importance difference in the Opto22 driver migrating from 3.8 to 4.5? Is there a known workarou
nd?
Thanks in advance
Mike
