01-23-2012 10:32 AM
I ran across this issue when recompiling one of my process files that uses the absolute value function. Some time after creating an expression using the absolute value function, if I go back to that expression, "abs" will be replaced with "must range between -1 and 1. The result is output in radians and ranges from 0 to PI" (see attachments). The absolute value will still be calculated, but if you recompile your process file you will get syntax errors.
I do not know if any other functions are affected in this way.
01-30-2012 10:29 PM
It's a bug
05-03-2012 02:39 PM
Is there a fix for the ABS function bug in Lookout 6.6?
10-18-2012 04:35 AM
Hi Ryan
I have now the same problem with the ABS function in Lookout 6.6
Is there a fix available?
Best regards
Dennis
10-18-2012 11:58 AM
I recall back in 5.1 there was a bug that would cause Symbolic Links to be replaced with "INVALID SIGNAL", causing the L4P and LKS to be corrupted.
Mike
06-20-2014 06:19 AM
Ryan, I am having this problem, what is the fix or work around?
06-23-2014 04:42 AM
What's your lookout version?
I don't remember there is a workaround. If it's not old version, I can build a fix for you.
06-23-2014 05:52 AM
Lookout 6.6 (build 49152)
06-23-2014 09:18 PM
Sent you a message. I'll build a fix and send to you.
06-25-2014 12:38 PM
Why not actually release it as a patch, you know how NI used to do things before every bug fix/introduction is a new "version".
