11-13-2014 03:20 PM
I have installed NI-VISA to my Ubuntu 14.04, however when i open it it doesnt seem to recognice my equipments that are connected through gpib [this connection is recognized in terminal when i run "lsusb" command]. I might be missing some packages but at this point i have no idea what i'm missing. Any help would be appritiated. Thanks for your help in advance.
11-14-2014 03:55 PM
If your Linux kernel is newer than 2.6.24, then GPIB USB support is not supported.
Check out these other threads for more details:
https://decibel.ni.com/content/thread/19705
https://decibel.ni.com/content/message/27374
If this is the case with your system, other GPIB devices should still be supported (although we do not officially support Ubuntu)
03-01-2015 06:48 PM
Hi:
A consideration should be made to support both Redhat/Centos and Ubuntu streams.
Redhat/Centos has a large server based following and with its very controlled release structure has become a favorite for EDA vendors.
Ubuntu/Debian seems to have a large following in the embedded space. Most users would choose to put this release on their lab laptop/netbook device. Debian offers a much larger library of software packages than Redhat/Centos making it a very powerful base upon which to mash up solutions from the wide software basek.
Peter
04-09-2015 06:20 AM
Hey vatpatel,
actually I'm trying to install it on my ubuntu 14.04 but I'm getting this error
gcc | Not found in current path |
*** ERROR: Some required tools are missing or were not found. ***
please can you help me ?
04-15-2015 09:20 AM
Hi Besmati:
gcc is installed by default in 14.04. I'd need to see a full log as well as the $PATH variable of your current shell to comment further.
Peter
04-15-2015 09:26 AM
All:
I was able to get NI-Visa to install on my Ubuntu14.04 system....partially.
I can't recall what forum I followed, but by using "alien" I was able to convert the NI-Visa RPM's to .deb files.
The NI-VISA package is 32 bits. This does not play nicely with pyVISA, if you are running on a 64 bit machine.
Is there any reason why NI-VISA for linux cannot be compiled for 64 bit machines?
I am considering creating a 32 bit Ubuntu 14.04 virtual machine, if only to test the link between pyVISA and the NI-VISA packages...... of course this won't connect me to real hardware......
Peter
04-15-2015 10:22 AM
You could try to install a 32-bit version of Python. It's a long process, but its doable in Ubuntu and you don't have to sacrifice any other software that supports Python x64.
The alternative I ended up using was to write C programs and control them with Python via popen, etc.
09-03-2015 01:07 AM
could you explain in details how you have install VISA driver on ubuntu?
10-04-2016 07:51 AM
This is strange. I installed NI-VISA in ubuntu 16.04, it worked, I caould connect to my tektronix, but could not read or write anything. But,today when I tried again, nothing worked, Idont think it loaded the modules. So tried to reinstall everything but it doesnt work anymore. Very strange. I haveno idea why it worked or why it doesnt work anymore. I installed it with
"sudo apt-get install alien" to be able to install rpm:s
and then
"sudo ./INSTALL --nodeps"
