03-18-2016 08:11 AM
I'm trying to get NI-DAQmx Base installed on Ubuntu 14.04 LTS 64 bit to use the C-Api and get the usb drivers.
Using Alien I could install the packages like mentioned here: http://maztories.blogspot.de/2013/03/ni-usb-6008-card-can-be-installed-in.html
When running lsdaq I get the following error:
$ lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
Error Message =Internal Warning 0x08B1734C : "lvinit.cpp", line 2181
LabVIEW version 15.0f1
For assistance in resolving this problem, please contact National Instruments Support.
/usr/local/bin/lsdaq: line 7: 3271 Aborted (core dumped) /etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices
Does anyone know how to fix this?
I know Ubuntu is not supported but I have to use it.
Any help would be greatly appreciated.
03-18-2016 10:32 AM
The log says the core was dumped. Did you save the core? If so, is it possible to send it?
03-22-2016 02:58 AM
Hey,
thanks for the reply.
I do have the core. I could send it per mail if that is okay.
01-10-2017 10:40 AM
has this been solved? I get the same error on Debian 8.0 64bit. I get this error on lsdaq and also on own applications linked with liblvrtdark.so.15.0 64bit.
01-17-2017 11:21 AM
Possibly this is caused by shell install scripts calling /bin/sh and using bash-specific syntax. "ln -sf bash /bin/sh" before install solved it. If this is the cause, the install scripts should be calling /bin/bash instead of /bin/sh.
