It's sleezy but another option is to power your basic stamp from one of the DAQ reference voltage outputs (or even DAC outputs) assuming that it's low enough power. Or you can use a ditital line in the DAQ (or serial port) to close a relay and power up your stamp.
Sheldon
Technical geek, engineer, research scientist, biodegradable...
