Hello Charlie,
I am trying to acquire pressure signals from the parallel port in order to calculate flow and volume waveforms and some time data related to flow waveform.
but i have some problems;
1- i need to automaticly measure and digitally display the inspiration time and expiration time which are related to flow waveform; inspiration time is the total duration of flow travilling on the positive side and expiration time is the duration of flow travelling on the negative side.
2- my sample rate is 200 Hz in the waveform graph. should i use and array to combine x and y values and should i use 0.005 value for x-axis.
3- when my pressure signal is zero at the input, i see 24 value on the inport at labview. how can i deal with it and pull the value to zero for zero input value.
other vaules of input are accurate. when i send 255, i see 255 on inport function.
i am attaching an example flow graph, and i will send a screenshot of my block diagram at my next message.
thanks for your help.
Burcu
