01-01-2006 07:54 AM - edited 01-01-2006 07:54 AM
Message Edited by student 16 on 01-01-2006 07:59 AM
01-01-2006 10:22 AM
01-01-2006 11:44 AM
Adding to Lynn's excellent comments;
Give us some timing paramaeters. How often is the data coming in and how long do you have to react?
These values can dictate IF and (if true) how this should be done.
Ben
01-01-2006 03:13 PM
Ben wrote: Adding to Lynn's excellent comments;
Adding to Lynn's and Ben's excellent comments, here are a few more notes on programming flaws. I don't have the VI analyzer, but it will probably find a few more. 😉
01-01-2006 07:19 PM
01-02-2006 09:57 AM - edited 01-02-2006 09:57 AM
Message Edited by student 16 on 01-02-2006 10:30 AM
01-03-2006 03:31 PM
Hi-
I aplogize for writing again, but i really need some help here...
If someone(Lynn , Ben, Altenbach, someone else...) can assist me to synchronize my application with the producer-consumer pattern, or a different solution, i'll be greatfull .
I would like to explain a bit why i need to work things out as soon as possible - The thing is that the prof. i am working with found( or to me more accurate- probably found) a way to depress epileptic seizures by using electrical pulses(ofcourse it is much more complicated then that..). To check that assumptiom first thing we have to do is get some preliminary results (using my application..) in order to see whether we should proceed further at all, and if we do to design an appropriate expermental procedure, and eventually to check it out with human beings.
Thanks again ,
Jonathan (student 16)
p.s - I've attached the llb to one of my messages.
01-05-2006 01:50 PM
Hi-
I aplogize for writing again, but i really need some help ...
If you can assist me to synchronize my application with the producer-consumer pattern, or a different solution, i'll be greatfull .
01-05-2006 02:36 PM
