10-16-2008 09:22 AM
Hi Friends,
I am trying to measure the distance between two R-R peaks and plot the respective frequeny spectrum from that, which is as shown in the attached picture. I could not find how to do it, kindly have a look at my vi.
Thank you,
abi
10-20-2008 10:20 AM
Take a look at the attached. I modified your existing program to read in the data and accumulate the R-R intervals and Heart Rates.
I also allowed the vi to remember the position of the last peak from the previous loop iteration so it can computer the data correctly. Also the program will ask for a file name and end when the EOF is reached.
10-21-2008 08:43 AM
Dear Mr.Pursley,
Thank you very much for mod vi, could you please explain me a bit about the changes you made in the mod vi.
Actually I am using a real time data and not from a file, so I tried replacing the input file by a Daq assistant to read the data here in this vi, but it doesnt work. Is it necessary to specify the file dialog to read the file every time. How can I get a real time data using Daq assistant in this vi.
Thank you,
abi
10-22-2008 09:46 AM
10-23-2008 03:49 AM
Dear Mr.Pursley ,
I have a question the vi is still asking for a file name every time I run it, but I dont want to read it frm a file, I want to read it directly from the Daq acqusition device in real time. So for this I just connected the DAQ device to notch filter as shown in the vi, but I think something is missing here. Kindly have a look at it.
Is it necessary to specify a file name every time, because it is just reading the data from the previous file and not the real time measurement when I run the vi.
Thank you for your time.
abi
10-23-2008 07:58 AM
Sorry about that. I added in the file read to double check the rest of the code and forgot to take it back out. The attached should be right.
10-24-2008 03:59 AM
Dear Mr.Pursley
Thank you once again for really helping me out, I will get back to you, if I have any questions in the future.
10-27-2008 04:44 AM
Dear Mr.Pursley,
In my program the vi is acquring data for 5 seconds only and then it stops, and all the varying parameters such as heart rate and R-R intervals stop after 5 seconds, and it remains the same, I mean it does not vary or continue further with time.
Say for suppose I need to check the data for 2-3 minutes continously´, the heart rate and the intervals also should change along with time, but thats not happening here, it just reads the data for first 5 seconds and the values remain constant, irrespective of how long you run the vi. I want to make this vi continously running with changing parameters. Kindly advise what I need to do in order to display this.
Thank you,
abi
10-27-2008 11:55 AM
The program I attached in an earlier message works fine for me. Make sure the Stop button hasn't been pressed before the program has even started.
10-28-2008 03:58 AM - edited 10-28-2008 04:05 AM
Dear Mr.Pursley, |
I checked it again with your mod vi it scans for the first 5 seconds and displays heart rates and R-R intervals, and this remains constant from then, only the locations are changing with time and not the respective Intervals and heart rate.
Is this normal, I am little confused here wheather its working correctly or not.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
