NI Home
Cart Cart | Help
You are here:
Reply
Knight of NI
Ray.R
Re: How to measure distance between R-R peaks
It appears that the most recent thread on this topic is found here.
Maybe it is best to continue the discussion within that thread only.
Yes.. it is confusing and my head is still spinning..  :smileywink:
(starting to) See Life in a brand new way...
b* ^ )
Member
marp84
[ Edited ]
hi bro i want to count this r to r ecg beat how i can do it please tell me
tanx
Message Edited by marp84 on 07-05-2009 09:02 AM
Member
ZJ.Gu
回复: Re: How to measure distance between R-R peaks
You could do peak detection firstly to find the R peak position and then, RR interval could be easily calculated.
Thanks!
Member
marp84
Re: 回复: Re: How to measure distance between R-R peaks
how i can calculated the RR interval, can you help me?
tanx
Member
ZJ.Gu
回复: Re: 回复: Re: How to measure distance between R-R peaks
If you have detected the R peak positions, you could get RR interval (n) = R position (n)- R position (n-1). n is the beat number.
Thanks!
Member
marp84
Re: 回复: Re: 回复: Re: How to measure distance between R-R peaks
how make it automaticly?
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
