NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
kannajin
EEG by USB6009
harlow, to everyone!!
What is ur opinion is use DAQ USB6009 to read signal we get from the brain?
the resolution for USB 6009 is 14-bit. are this enough??
sample rate is 48 kS/s
 the min voltage is  (-1/+1) but our brainwave only around 10UuV, this can be slove if we gain it till 1V
is around 1000 times.
will this spoil the wave n  more noise?
My design for amplifer is  Instrument Amplfier --> low pass -=-> high pass --->  amplifer (100times) --> notch flier--> non-inverting amplifer--->otocouple.
any idea for it?
Trusted Enthusiast
Coq_Rouge
Re: EEG by USB6009
Hi Here is some eeg stuff http://openeeg.sourceforge.net/doc/modeeg/modeeg.html. You might find it useful, or not :smileywink:. I also think the basic idea pass the sanity check. A problem might be the last stage. The optocoupler. Almost all of the optocouplers on the marked are digital. But Agilent’s HCNR200/1 and HCPL-4562 constitute basic optical coupling building blocks. I also think Fairchild Semiconductor has something that can be used. Anyway Google the phrase "analog optocoupler" I will also recommend using battery as powers supply e.g. two 9 volts cells (giving +/- 9 volt). The reason for this is that batteries are a very low noise power source. I think noise is your worst enemy in this project. So you have to design the analog front-end with this in mind all the time. Battery is also good for the safety aspect. The problem is that battery gets worn out. But you may use an external power supply while experimenting and batteries then you are measuring on humans. good luck
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Member
Steve.J
Re: EEG by USB6009
The resolution will be enough - the dynamic range of EEG signals is not that great (unless you need to capture EEG during a seizure).  12-bits is plenty.  One possible issue is that the 6009 product is a multiplexed A/D so each channel is scanned/sampled in sequence, which could lead to loss of accurate phase information.  This may or may not be a concern for you depending on how the data will be collected and used.
There are still lots of analog optical isolation modules on the market - search for "isolation amplifiers".  Analog Devices has a good selection.  Battery power for the front-end makes a lot of sense, but you still need to be worried about DC fault currents even from the battery.  AC coupling the instrumentation amplifier solves this issue, as well as blocking the DC offsets from typical surface electrodes.
Steve
Visit the NI Biomedical User Group at:
www.ni.com/biomedusers
Member
kannajin
Re: EEG by USB6009
hi, steve
what do u think if use RS232 pc port communicate with labview?
so the RS 232 will sent data from the Microcontroller to Labview to show the wave??
do u have any example on it?
Member
Steve.J
Re: EEG by USB6009
You should be able to do this fairly easily...you can use relatively high baud rates when using direct connections between microcontrollers and PCs.  You will need to determine how to bundle the data that you are sending from the microcontroller...RS-232 is usually used to send 7 or 8 bit data (usually in the form of ASCII characters) so you will have to devise a scheme to send two bytes (or characters) per data point for each channel, and the LV application will need to be able to take the two bytes and assemble them into a 16-bit "word", then apply a scaling factor to convert this 16-bit value to a floating point number that represents the actual amplitude of the EEG signal (in microvolts).  Usually some form of a header is sent (special character or string) that allows the LV application to identify the start of a sequence of channels/data and often the calibration or scaling factors are also sent as part of the header.  This allows the LV program to periodically reconnect and syncronize to the data stream if something goes wrong.  Look through the serial examples that ship with LV to get some ideas.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
