NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member 603
Member
603
EEG block diagram
I am a student in BioMedical could any body help me in making a program to record EEG signals  ,please.
I do not know any thing about labview. please help me
Knight of NI
Knight of NI
tst
Re: EEG block diagram
Your request is very general and has absolutely no details.
I suggest you that you start by searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
After you've learned this and know exactly what you want to do (hardware, software requirements), you can try searching for "EEG" and see if anyone has done anything that can help you.
___________________
Try to take over the world!
Member 603
Member
603
My project is about designing a system to measure the brain waves and show the signals in computer software. Our system consists of electrodes, amplifier and uses DAQ to see signals in pc. Our expectation is to present the EEG alpha and theta waves.
Proven Zealot
johnsold
First, be sure your amplifiers are properly rated and isolated for safety of the experimental subjects.
I have worked on some neuroscience projects involving theta. Our theta detector (LV5.1) consisted of low pass filtering the EEG at 25 Hz and then taking FFT on a sliding window of the data. When the ratio of the energy in the theta band (~3-7 Hz if I recall correctly) to the energy outside the band exceeded a threshold, we decided theta was present. Today I would probably use the Point by Point FFT to simplify the program a bit.
I have briefly looked at curve fitting to detect theta in smaller samples, but have not worked out all the bugs.
Lynn
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
