11-13-2013 03:49 AM
I develop an x64 application, which uses a SQL database and it works in debug and release, if I start the application from cvi. The application does not work (I get "Automation error code -2147024809 0x80070057 invalid parameter.") if I start it from outside if Windows, e.g. by starting it from the explorer.
Did anyone else have such a problem? And how to solve it?
11-13-2013 05:01 AM
I made the smallest possible out of my project and the problem still exists. Maybe someone can test it and say if it is an problem with cvi or my pc.
The problem seems to be a problem with cvi and SQL.
These are the combinations and errors I get:
Can anybody tell me, what can cause this?
11-14-2013 01:23 AM
Ok, as I found out how to configure a 32bit ODBC on a x64 system I tried my program as 32bit version and it works flawless. So it seems that this is a problem with 64bit programs/libraries!?
11-14-2013 07:39 AM
are you using multithreading?
Because this info is maybe a solution for your problem:
"a customer that is using CVI 2012 and SQL Toolkit 2.2 on a Windows 7 64-bit OS. When the customer builds a 32-bit application to communicate with his mySQL database and enables multithreading using the command DBInit (DB_INIT_MULTITHREADED), everything works fine. However, when he builds a 64-bit application, he gets the following error when running his application:
"Automation error code -2147024809 0x80070057 Invalid parameter"
In both 32-bit and 64-bit applications, he is able to use DBInit (DB_INIT_SINGLETHREADED) without problems, but due to their application requirements, they need to be able to do multithreaded communication.
Solution:
Calling DBInit for multithreaded does not actually set the threading model to multithreaded. It instead defers the decision until later [......]use CA_InitActiveXThreadStyleForCurrentThread(0, COINIT_MULTITHREADED) to set the threading model
11-18-2013 04:45 AM
Thanks, I will try it (although we have decided to go with the 32bit version as it also gives less problem with the distribution) and this also explains why my other program is working ok in 64bit.
Do I have to do this in every Thread that is using SQL functions? Because DBInit() is just called once, but the function name of CA_InitActiveXThreadStyleForCurrentThread implies that the configuration is only valid for the current thread?!
11-20-2013 03:54 AM
So I tried it and it worked 🙂
So thanks for the solution.
