05-09-2014 06:39 AM
I want to create a table and fill inn the header in bold and there after fill the rest of the table in non bold. CVI2013 and Word 14.0.7116.5000 (32 bit)
This is what I do.
WordRpt_SetTextAttribute(docHandle, WR_ATTR_FONT_SIZE, 12.0);
WordRpt_SetTextAttribute(docHandle, WR_ATTR_FONT_UNDERLINE,WRConst_FALSE);
WordRpt_SetTextAttribute(docHandle, WR_ATTR_FONT_BOLD, WRConst_TRUE);
WordRpt_SetTextAttribute(docHandle,WR_ATTR_TEXT_ALIGN,WRConst_AlignLeft);
WordRpt_AddTable(docHandle,2,7,&tableHandle);
filling in table header in bold by WordRpt_WriteToCell(tableHandle,1,1,"som text"); (column1,2,3....)
Then chainging to non bold by WordRpt_SetTextAttribute(docHandle, WR_ATTR_FONT_BOLD, WRConst_FALSE);
The filling row 2. The text remain bold
I have the same problem with WordRpt_SetTextAttribute(docHandle,WR_ATTR_TEXT_ALIGN,WRConst_AlignCenter);
05-13-2014 08:19 AM
Hi fluidtronic,
I am not experienced in CVI, but I did some checking and I cannot see that you did any misstake. Do you have the source code of some example that I can test with? I found some examples, and you should be able to change the behaviour with "WRConst_FALSE" and "WRConst_AlignCenter" the way you did. Maybe if I can see the whole code it might be more clear.
Could you try to do a program without the table, but only with rows of text? Does it work for you to switch between bold and regular text then? Also, left and center justified text? If yes, the way you add the table might affect how you change text properties.
