LabWindows/CVI
word report : checkbox
I have a question about the Word report generation with LabWindows CVI.
I want to check or uncheck some checkboxes with CVI.
I did not find a function in CVI library (Word Report) that changes checkboxes value.
Is it possible to do it (in a simple way)? If this is not the case I will arrange to remove the check boxes.
Danaé P.
(4,572 Views)
Hi D1431,
Sorry for the late reply,
There is no functions in CVI word report library that allows to check or uncheck a checkbox in a word report.
However you can use an Active X server in CVI: http://www.ni.com/white-paper/2714/en/ to get access to all the functionalities and functions available for Word (http://www.extendoffice.com/documents/word/993-word-insert-check-box.html for instance).
Hoping it'll help you.
Best Regards
Louis
National Instruments France
(4,445 Views)
