I borrowed the usages of these two functions from Excel200dem.prj. But the cell range indexing is acting weirdly. If I want to access to cell range A1-A700, A2-701, A3-A702, and A4-A703, I'm actually accessing to ranges A1-A700, A3-A702, A5-A704, and A7-A706 respectively.
You may suggest me to use Safe Array. I'm now using it to write the data, but when I try to read, it seems to only support 2-dimension reading (there is a function CA_Get2DArrayElement(), but no function like CA_Get1DArrayElement() ).
Pls somebody can help either of the problems. Thank you very much.
Jason
