07-01-2014 01:09 PM
I'm encoutering a problem that appears to be specific to the LabWindows/CVI version number. I've attached the code and the problem I'm encountering is that I get Build failures for using a type_def enum type that is already declared in a header and included at the top of the program. The specific error that I'm encountering is "unknown type name "int_err."
My version of CVI is 2013 Service Pack 1 (13.0.1 (201)). A coworker is able to successfully build this project on version 12.0.1(127), so obviously something must have changed.
Any ideas?
Solved! Go to Solution.
07-02-2014 12:57 AM
Your project seems to miss error.h... Is the the place where you define int_err?
07-02-2014 08:31 AM
Oops. Apparently it didn't attach. Here it is.
07-02-2014 09:22 AM
With the file provided your project compiles and links fine without any warning or errors (I am also using CVI13.01)
However I noticed that in your project the path to error.h is different, so maybe - by accident - you included a wrong error.h file... could it be?
07-03-2014 09:41 AM
Yes that appears to be the problem. Thank you!
