LabWindows/CVI
type_def enum build error in CVI 2013
I'm encoutering a problem that appears to be specific to the LabWindows/CVI version number. I've attached the code and the problem I'm encountering is that I get Build failures for using a type_def enum type that is already declared in a header and included at the top of the program. The specific error that I'm encountering is "unknown type name "int_err."
My version of CVI is 2013 Service Pack 1 (13.0.1 (201)). A coworker is able to successfully build this project on version 12.0.1(127), so obviously something must have changed.
Any ideas?
(4,487 Views)
Your project seems to miss error.h... Is the the place where you define int_err?
(4,473 Views)
Oops. Apparently it didn't attach. Here it is.
(4,459 Views)
Accepted by topic author asapienza
With the file provided your project compiles and links fine without any warning or errors (I am also using CVI13.01)
However I noticed that in your project the path to error.h is different, so maybe - by accident - you included a wrong error.h file... could it be?
(4,453 Views)
Yes that appears to be the problem. Thank you!
(4,433 Views)
