12-10-2014 07:35 AM
I'm setting up a new application framework for the re design an existing application to work in both English and Chinese and any future language for that matter.
I have sorted the localization of the panels and how to change the text in the various controls at runtime and this all works just fine. The only problem I'm having is the title bar on the Message Popups and the title bars of the panels.
Firstly the panels, even if I localize the title string with the translation tool into the .lwl file when I run the application it is not using the correct character set. I have a similar issue with the MessagePopup box, if I call
SetSystemPopupsAttribute(ATTR_TEXT_CHARACTER_SET, VAL_GB2312_CHARSET);
MessagePopup("\xba\xc9", "\xba\xc9");
Then I see what in the attachment, the message text is correct but the title is not.
Has anyone hade a similar issue and solved this problem?
Thanks Mark
12-22-2014 06:11 AM
Hi Mark
Could you write and include a small example problem that demonstrates the problem?
Thanks James
07-05-2016 07:42 AM
Dear Friend,
Could you do me a favor and tell me how to translate those run-time message into Chinese since I have to localize our GUI into Chinese?
For .uirs, I could translate them correctly by localization tool. However, I do not know how to translate those popout messages or run-time messages.
Thanks a lot,
James
Email: xiaohong_ouyang@arxtron.com
Tel: 647-786-8600
07-18-2016 11:39 AM
This article should be able to help you with that, especially the third paragraph.
07-18-2016 12:26 PM
For your own messages that are not stored in the runtime messages file here is what I do: I paste the Chinese into Word, and then "Save As" a plain .txt file. It then provides a "File Encoding" dialog where I select "Other encoding" as shown below.
"Chinese simplified GB2312" has worked fine for me, but I know nothing about Chinese 😉
Your text file will look like a mess (at least on my English version of Windows it does) but those strings render as Chinese in your CVI app on a Chinese version of Windows. Be careful about string lengths, of course!
Hope this helps.
07-18-2016 12:39 PM
Thank you very much for the valable information.
09-25-2019 01:04 AM
5 years later I still have the same problem and have not found a solution yet. I have an application with texts in different languages, language is changeable at runtime. With the Chinese texts everything except for the titlebar works fine. What have you done to show the Chinese texts also in the titlebar?
Marion
