Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
10-18-2014 12:15 AM
Hey! I want to make a thumb impression system in Labwindows/CVI
Is thiss possible to make it using this tool ?
10-18-2014 04:15 AM
Yes. With programming in C you can achieve almost everything 😉
10-18-2014 10:36 AM
@xhakil26 wrote: Hey! I want to make a thumb impression system in Labwindows/CVI Is thiss possible to make it using this tool ?
The question makes no sense, you need to give more detail.
You seem to suggest a software solution to a hardware problem. You cannot "make" hardware using software.
Do you have an existing thumb impression system that you want to control with software?
If the programming interface is documented, you can interact with it using any programming language.
Thanks!
We'll be in touch soon!
