LabWindows/CVI
there is a difference between the results from labwindows and VS
hello,
        I use the same procedure  to process the same data respectively by Labwindows/CVI and vs, and got two differents rusults, how does this happen?
        Attached both Labwindows/CVI and C++program. Read data from "JFfg5.txt" and output the results to the "out.txt".
Message 1 of 1
(2,638 Views)
