Hi all,
i have am having a intermitent issue with a program. first let me give you the issue and then the specs.
This is an inconsistant program lockup. when the program runs in an, .exe format it runs fine for an hour to a couple of days and then goes to a white screen and freezes. the program is basically just continiously reading a DAQ card and comparing readings to set values.
if i have the program running in Debug mode thru CVI and it freezes, CVI sees it as running (in top left hand corner of CVI interface), if i push the stop button (break execution) the break execution dims but the program never stops and the Running indication is still active.
question--- is there another way to stop the program while it is in this frozen state to see where the issue is hanging up. like a hard stop command ????
I can only stop the program by using task manager and ending CVI there. which does me no good in finding the freezing point.
CVI 2012 sp1
with a PCI 6071E DAQ
