05-21-2014 06:37 AM
urgent!!!!!!!! je suis entrain de realiser un projet sous labwindows/cvi , je veux un programme bien sur en language C qui me permet de lire et recuperer les données numeriser par un carte son,et de le mettre dans un fichier .txt pour le manipuler dans mon logiciel labwindows/cv
s'il vous plait aidez moi ????????????????:manembarrassed:
EN ANGLAIS/
Iwant to have the code in C language about data sound card ,i want to use the data cardsound and to practise the data in labwindows/cvi
05-22-2014 05:51 PM
Good Day
Do you want to grab the data off of the sound card in CVI
or
Do you want to process the data that is stored in a file after a different application captured the data?
05-22-2014 07:22 PM
think you verry ......................................much:
so that the signal sensed by a sensor, signal will be digitized by the sound card, so for acquirir this signal.
how I read this table value digitize and store in a file.txt to the processing of this signal in my application LabWindows / CVI???????????
please help me
05-23-2014 08:48 AM
I want an answer as soon as possible if you want because it is essential for my final project study
05-23-2014 12:32 PM
I await your response is urgently
05-27-2014 08:36 PM
CVI does not have any native functionality to record sound or pull information from the sound card. Sorry. You may want to look into the Window API to see if there is a function that you are looking for.
http://msdn.microsoft.com/en-us/library/windows/desktop/dd370802(v=vs.85).aspx
Sorry I could not be more help. Good luck on your project.
06-03-2014 05:03 AM
has all the national group / instrument about the problem posed above, time passes very quickly and I found nothing about my program, I want a solution,
12-30-2014 06:52 AM
Hello everyone
I am looking for a function to acquiriri emenant the signal from a microphone connected to a PC
thank you
12-31-2014 02:05 PM
Salut,
Comme Connor a dit, il n'y a pas de fonctionalité en LabWindows/CVI pour lire et récuperer les données d'un carte son. La meilleur option sera de chercher pour une fonction dans le API de Windows en suivant le lien qu'il vous a donné.
Bonne année!
