have a file where I would like to jump to different lines (label jumps). For this I use the "Set File Pointer" command to jump to the beginning of the file. I use the "Scanfile" command to look for the corresponding line. Sometimes this file is very extensively, which partly lasts for a very long search. Is there a possibility of searching the file from the present position backward, because the searched line is always some lines above the present position. It is not possible to use an offset for scanning, because the distance to the corresponding line is variable.
