02-05-2015 05:48 AM - edited 02-05-2015 05:50 AM
dear cvi-programmers,
i 've some problems with a simple ring control in a cvi panel. the ring has multiple items. no matters which item i select, the result will always be the first item. i can't select any other item than the first one (i'ts not necessarily the default-item).
when i redraw the panel, it works for the next few days. but somday in release-built (production-application) the ring control selection no longer works. when i start the uir-file in the labwindows cvi gui editor i can understand the problem. Even in the "operate" mode i can not select any other items than the first one.
when i convert the ring-item into another ring (F11-Key), and then convert it back into the original it will work again (1-2 days).
when the problem appears, the file content is still the same!
i also redraw the panel in different versions of labwindows cvi (2010/2012/2013), still the same problem.
other ring-control on different panels (several controls more), never came up whith this effect.
any guys out there whith the same problem?
the corrupt uir-file is in the appendix.
thank you !
kind regards,
lukas roeder
02-05-2015 06:39 AM
Hi Lukas,
if you suspect the UI file to be corrupted, you can
- save it in a different version (e.g. 2013 instead of 2010) and see if it does make any difference
- save it as a TUI text file and re-import it (Options / Save in Text Format)
02-05-2015 06:57 AM
hi wolfgang,
thanks for your answer 🙂
do you have the same effect, when you open bei uir in your cvi ?
i don't think the file is really 'corrupted', cause the content of the file is still the same. i compared the local file with the orginal (from a svn-server) with a compare-tool.
i 've also tried to make the file in cvi 2010 / 2013.
and i 've also tried to run the exe on cvi 2010 / 2012 / 2013.
always the same problem..
but now i will try the tui-thing. but i think it will works 1 or 2 days, and then the problem appears again.
kind regards
lukas roeder
02-05-2015 07:02 AM
yes, I could reproduce your behavior - but not explain it
02-05-2015 09:01 AM
Lukas,
it looks that saving the UIR file in TUI format and then loading it from disk solves the problem. Which is what Wolfgang suggested.
Also, converting between different types of controls (F11) seems to make the issue go away.
I suspect that the issue is caused by a UIR corruption. Can you reliably reproduce the scenario in which your UIR is corrupted and the bug appears. I.e. reliably providing the following:
Best regards!
- Johannes
02-06-2015 06:05 AM
Hi Johannes_T,
unfortunately i can not reproduce the scenario in which your UIR is corrupted and the bug appears. cause it's a production application..
so the F11-Solution is not really nice, cause i can not always go into the production room, when the problem appears.
i've made a text user interface (.tui), as wolfgang suggested, and this is the solution !!
no the ring control is generated from code, whenever the programm has startet.
i think, may it was a problem with the background-process of the ring-control..
thank you guys for your help !
kind regards
lukas roeder
02-10-2015 04:19 AM
I remember having strange UIR corruption issues when saving uir files to a CIFS share or a VirtualBox share (CVI inside XP guest, Linux host). It happened in CVI 2010 IIRC and has been fixed since then.
