07-22-2015 09:42 AM
I have a simple database called mydb. I am trying to retrieve data from a table in the database called SN_data. I am trying to retrieve a serial number (long int) from SN where ID = 1. I can find the record but cannot display the data. Is there a simple example that demonstrates retrieving data?
07-23-2015 01:45 AM
By searching in the examples with "SQL" keyword you will be prompted with several examples (readtab, readtab2, readtab3) that shows you alternatives to find and read records from a database. Readtab3, which uses random acces and maps, is probably the example that is more useful for your needs.
07-23-2015 05:12 AM
I have an example running. Is it possible to run a query that is defined in an access database from CVI and obtain the results from it without generating the query in cvi?
07-23-2015 06:46 AM
I cannot answer on this as I'm not using MS Access databases.
