Yes, you can use AISampleChannels to do what you want. The second parameter is for the list of the channels you want to read from. For example, if you want to read channel 0 to 2, you'll have "0:2", or "0,1,2". The last parameter will contain the data for all the channels, in the order you specified in the second parameter.
You can right click on each parameter control on the function panel and it opens the help file for the parameter.
Mika Fukuchi
Application Engineer
