LabWindows/CVI
programmatic table won't hear commits
I have a table control that I'm creating programmatically by NewCtrl.  I set its control mode to VAL_HOT so that it will listen to commit events when I edit the cells.  And yet, the EVENT_COMMIT never happens.
As a test, I created a table in my UIR, set it to hot mode, and put a DebugPrintf in the  EVENT_COMMIT case.  Triggers as expected when I edit a cell.
Now back to my programmatic table, all my other events are triggering as expected:
  • EVENT_RIGHT_CLICK
  • EVENT_LEFT_CLICK
  • EVENT_LEFT_DOUBLE_CLICK
  • EVENT_GOT_FOCUS
  • EVENT_LOST_FOCUS
  • EVENT_TABLE_ROW_COL_LABEL_CLICK
What else do I need to set in a programmatic table to make commits respond?
(3,680 Views)
Remember that individual cells can have a different state with respect to the table as a control.
It may worth a trial calling SetTableCellRangeAttribute (panelHandle, PANEL_TABLE, VAL_TABLE_ENTIRE_RANGE, ATTR_CELL_MODE, VAL_HOT); after creating the table.
(3,677 Views)
No change.  This is very odd.  A separate control button inserts rows into this table.  I extended this function for my UIR-based table (thinking that maybe it was the insertion of new rows that were not also being set to HOT mode).  But no such luck, even as I insert new rows on the UIR table, each additional row and cell responds to commits.
Another data point: if I change my UIR table from HOT to INDICATOR or NORMAL, only under the Control Settings (see attachment), then my EVENT_COMMIT events never happen, just as I would expect.
So the question is, how is CVI making this setting to the table?
(3,674 Views)
Accepted by topic author ElectroLund
Ok, I have this solved now.  It was a mixture of issues.  This project is part of my other set of questions here, wherein the first thing that happens during my test is that I switch monitors (with the help of a DiscardPanel and DuplicateCtrl).
For whatever reason, the DuplicateCtrl does not seem to duplicate the control mode status.  So after I move monitors and call the DuplicateCtrl, I must reissue a call to change its control mode attribute.  Turns out, just this one is needed:
SetCtrlAttribute(mainPanel,tableControl,ATTR_CTRL_MODE,VAL_HOT);
(3,662 Views)
