LabWindows/CVI
problem updating ini file ini file
i get input ip address from the user and replace the previous ip address in the .ini file with latest ip address but the issue is this that when a user enter the ip address and i write it to my ini file it is not done at once but if i do it twise by calling same function from my command button twise then my ini file is updated , this is strage although iniwrite function returnes success on first attempt as well ; which i have checked with breakpoint but when i do it twise then it is done , please guide me in detail , i am really amayzed by this strange behaviour ..
Message 1 of 15
(5,689 Views)
Can you post the relevant code?
Message 2 of 15
(5,690 Views)
can u start with ininew(1) for the handel returne or ininew(0) is must if i am using one ini file  ?? can this be the case , i dont have code right now on this pc. but i know that i have use ini file for initial loding of parameters and then finally in a callback for mordification by the use and i have not used ini file in different threads which is recommended by cvi to not use ini in multiple threads
Spoiler
Smiley Happy
Message 3 of 15
(5,686 Views)
The parameter for Ini_New has no effect on the behaviour you are seeing.
It's difficult to try guessing what's happening without looknig at the code: may there be some condition that prevents writing down to disk the updated IniText object on the first run? Try step-running the code to see what happens.
Message 4 of 15
(5,682 Views)
Ini_WriteToFile(iniText, pathName);  //
Ini_PutString (iniText, "section 1", "tag 1", "string 2");
Ini_PutInt (iniText, "section 1", "tag 2", 8080); // or any other value i get from popup dialog box
//then close popupdialog
the issue i am facing is that when i press command button and this writing to file code executes then after pressing the button once my desired job is not done although wrietofile code is hit which i have checked using breakpoint but when i press the button second time the job of writing to file is successful although this is the time when my code is executed second time
// now more testing i did
i chage the ip address when ever i press the button and what i found was that the one precious statment was written rather than the latest
e.g
i enter 8080 value changed on inifile none
i enter 8081 value changed on inifile 8080
i enter 8082 value changed on inifile 8081
i enter 8083 value changed on inifile 8082
i enter 8084 value changed on inifile 8083
i enter 8085 value changed on inifile 8084
how is this happening ?? why is this happening ?? i tried changing tag postion and even there order nothing happend ... please help me it feels as if some gost is delaying my input by one Smiley Frustrated
Message 5 of 15
(5,633 Views)
The problem is that you need to update the tag/value pairs before, and write them to disk as the last thing:
Ini_PutInt ()
Ini_PutString ()
Ini_WriteToFile ()
Message 6 of 15
(5,627 Views)
what u mean by updating tag values and how to update tag values ?? can u guide please Smiley Surprised
Message 7 of 15
(5,610 Views)
Accepted by topic author smartprogrammer
Smiley Frustrated
I already gave you the exact order of functions in my preceding message!
Ini file instrument builds an object in memory which permits you to store and locate values. This object can be populated reading from a file on disk; similarly, it can be saved on a file on disk. These are the very first and last operation to perform if you want an up-to-date image of your values on disk. There are three layers to consider:
  1. The file on disk
  2. The IniText object in memory
  3. The variables specific to your program
With this in mind, the correct sequence to update the file on disk so that it reflects the value your variables have in memory is:
Ini_New           Create the object in memory
Ini_ReadFromFile  Populate it with disk content
Ini_Get           Read from the memory objecy into variables in your program
Here tou can update program values
Ini_Put           Update the memory object with the content of your variables
Ini_WriteToFile   Save all to disk
Ini_Dispose       Clear memory
Since you are saving to disk before calling Ini_Put functions, the disk image is not up to date
Message 8 of 15
(5,597 Views)
Saying it graphically:
Message 9 of 15
(5,595 Views)
thanks alot so nice of you , i respect u :manvery-happy:
Message 10 of 15
(5,570 Views)
