Hello
CVI is an ANSI C compiler, so you probably wont find most of the POSIX functions available with the compiler. But if you can find C libraries that implement these functions, you can always use those with CVI. And CVI does provide libraries that will work with other compilers as well, since some other compilers might implement the functions you need.
I know this isnt the answer you were looking for but I hope this explains things
Bilal Durrani
NI
Bilal Durrani
NI
