Here is a very simple code : #include #include void main( void ){ printf("Output testing\n"); exit(0); }
I can compile and run it either in CVI or MSVC. If in a command prompt window I run the command : MyProgram>log.txt Then using the MSVC version works fine and I get the expected file on disk. However, using CVI I got an empty txt file. Do you have any idea about what is going on and why the CVI version is not working ?
By the way the "usefull" but non ANSI C following functions are not available in CVI :
1- isatty 2- fileno
Do you have any idea about how I could emulate them ? Regards, Philippe
CVI is an ANSI C compiler, so you probably wont find most of the POSIX functions available with the compiler. But if you can find C libraries that implement these functions, you can always use those with CVI. And CVI does provide libraries that will work with other compilers as well, since some other compilers might implement the functions you need.
I know this isnt the answer you were looking for but I hope this explains things
