01-19-2013 03:16 PM
Hello, all.
I am trying to get an Opal Kelly XEM3005 board up and running with LabWindows/CVI 8.5.
I have been in touch with OK's Tech Suppt, and have run down the initial issues of "bool" types. After having (at OK's recommendation) with "char" types, I can now include the headers without errors.
There is, however, a new problem:
When I call the constructor function, which should return a pointer to an "okFrontPanel_HANDLE" type, I am getting an error for a missing prototype for the constructor(s).
Dredging through the .c(pp) file, I found the following:
Relevent code snippets included below:
try1.c:
#include <cvirte.h>
#include <userint.h>
#include "Try1.h"
#include "XEM.h"
#include <windows.h>
//#define _WIN32
static int panelHandle;
static okFrontPanel_HANDLE XEM_Device;
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpszCmdLine, int nCmdShow)
if (InitCVIRTE (hInstance, 0, 0) == 0)
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "Try1.uir", PANEL)) < 0)
return -1;
DisplayPanel (panelHandle);
RunUserInterface ();
DiscardPanel (panelHandle);
return 0;
int CVICALLBACK Connect (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
int Value = 0;
switch (event)
case EVENT_COMMIT:
GetCtrlVal(PANEL, PANEL_CONNECT_SWITCH, &Value);
SetCtrlVal(PANEL, PANEL_CONNECT_LED, Value);
if( Value )
XEM_Connect(XEM_Device);
else
XEM_Disconnect(XEM_Device);
break;
return 0;
int CVICALLBACK Quit (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
QuitUserInterface (0);
break;
return 0;
XEM.c:
int XEM_Connect ( okFrontPanel_HANDLE XEM_Device )
int NoDevices = 0; // Number of devices attached to the PC
// Load the DLL (?)
// Load the FrontPanel DLL
if (FALSE == okFrontPanelDLL_LoadLib(NULL))
printf("Could not load FrontPanel DLL\n");
exit(-1);
// Find out how many devices are attached
// XEM_Device = okFrontPanel_Construct();
XEM_Device = okCFrontPanel();
// NoDevices = okCFrontPanel();
printf("%d OK devices attached\n", NoDevices);
// Call the contructor?
// okCFrontPanel ();
return XEM_SUCCESS;
int XEM_Disconnect ( okFrontPanel_HANDLE XEM_Device )
// Call the Destructor (?)
// ~okCFrontPanel ();
return XEM_SUCCESS;
01-21-2013 10:16 AM
Hi tomii,
It looks like you posted another very similar thread about compiling errors with your Opal Kelly dll's here. I will be following up in that thread to help get some traction with these issues.
01-21-2013 10:28 AM
Well, I started this new one to give more info, as things have progressed some, and the answers I was getting in the other were not especially helpful.
Right now I'm at a linking problem (I think)
01-21-2013 10:28 AM
Let me rephrase. Yes, there is a new thread with much more recent info in it. Sorry for the confusion
