01-15-2013 06:37 PM
I'm using LabWindows/CVI v 8.5
I have created the worlds 2nd simplest GUI, a quit button, a switch, and an LED that reflects the status of the switch. This works fine.
When I include the okFrontPanelDLL.h file (and that's all), the thing refuses to compile. It appears to be choking on a "bool"
I have had the GUI creater create a winmain, and I have gone into my options and made sure the settings are VisualC++.
Any clues? I can include code and projects if necessary.
01-15-2013 11:24 PM
CVI means C, not C++
01-19-2013 03:08 PM
*THAT* is really unhelpful...
01-20-2013 02:03 AM
That's sad to read. It should have told you that CVI is choking on your bools because bool is not C, but C++. Fortunately it seems that you have solved your problem now.
