Since you don't know what got trashed when your PC was repaired, I suggest you 'un-install' labview, (maybe even de-fragment the disk to improve performance) then install labview again. This should give you a clean copy. Then re-install your board drivers & see if the code will then work. If not, contact the guy that wrote the programme!
