12-03-2014 11:35 AM
I have a .Net assembly, which I have attached that when I run the Create .NET Controller all I get is two functions. They are the Initialize and Close. I don't get any of the other public functions in the .fp file.
Using a .Net Viewer like .Net Reflector I can see all the public functions that are suppose to be in the dll. The .dll is a 64-bit assembly and I am running LabWindows 2013 SP2. I am trying to develop a 64-bit application and need this dll to talk to the instrument.
Paul
12-04-2014 04:48 PM
Hi Paul,
This KnowledgeBase Article references the problem you are having. Basically, for unsupported types or for private/protected entities, the functions will not be generated in the instrument.
I hope that helps to get you started.
12-05-2014 07:46 AM
Steven,
So basically nothing can be done.
Paul
12-08-2014 11:42 AM
Paul,
Looking at the attached DLL, it appears that all the classes are in the default namespace. If they can be added to a new or different namespace, you should be able to create a .NET Controller in LabWindows™/CVI™. Beyond that, there is nothing I'm aware of that can be done.
12-08-2014 03:14 PM
Steven,
I have talked to the vendor, they are unwilling to recompile the dll since it works for everybody else and not LabWindows.
Paul
12-09-2014 06:23 PM
I've been asking around on how to approach this. It would theoretically be possible to write a .NET wrapper which exposes your needed functions in a named namespace. You could then create a .NET Controller for that wrapper.
12-10-2014 08:35 AM
Yes I can see how someone could do that using C#. I will give it a shot.
