LabWindows/CVI
multiple lines of text on a command button
Is there a way to get multiple lines of text on a command button.  Instead of a wide button with the text " Start Test System".  I would like a tall button with 3 line.
  Start
  Test
System
(4,744 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
While editing comman button label in the UIR editor you can split text into lines with Ctrl+Enter.
If you are setting the label programmatically, embed '\n' code into the label text.
Both methods work for all control types, not only for command buttons.
(4,737 Views)
Thanks, I thought it would be simple.
(4,714 Views)
