10-12-2015 04:08 PM
Is there a way to get multiple lines of text on a command button. Instead of a wide button with the text " Start Test System". I would like a tall button with 3 line.
Start
Test
System
10-12-2015 05:37 PM
While editing comman button label in the UIR editor you can split text into lines with Ctrl+Enter.
If you are setting the label programmatically, embed '\n' code into the label text.
Both methods work for all control types, not only for command buttons.
10-13-2015 07:53 AM
Thanks, I thought it would be simple.
