Hello Siddu �
It looks like you are adding an instrument driver to a device with a logical name in MAX.
First, download and install an
instrument driver. If you are using LabVIEW, install the instrument driver to the LabVIEW instr.lib directory. If you are using LabWindows/CVI, install the instrument driver to the CVI/instr directory. You can access instrument drivers from the instrument menus. For information on using instrument drivers with other programming languages, see the Getting Started link below.
Now that you have an instrument driver, see
Getting Started with Instrument Drivers for instructions on access an
d use.
Click
here for basic support links on instrument drivers.
If these suggestions do not solve your problem, please reply with information specific to the instrument driver you are using. Have a great day!
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
