09-12-2007 10:05 PM
09-13-2007 02:00 AM
09-17-2007 08:52 AM
Hi test_man,
A dll can only be loaded into a processes memory once. The way I got around this is to write a wrapper for the LoadLibrary function. LoadLibrary returns the same handle if the dll has already been loaded. The wrapper keeps a running list of handles that have been loaded by the system. If a handle returned by LoadLibrary is already in the list the dll is copied to the windows temporary directory. The copied dll is then loaded and gets a new handle (and memory space). If you need to load the same dll more than twice you will have to name all the dlls differently.
09-17-2007 09:16 AM
But if the underlying instrument driver design cannot cope with more than one instrument at a time, this approach will not overcome that limitation. For example, it is common to use a Windows Mutex to ensure that only one instance of a driver is in control at any time - this will apply even across different process spaces.
It sounds as though this particular instrument driver concept is weak if it can only support a single instance, so I wouldn't expect too much from trying this technique.
JR
08-01-2008 01:06 PM
08-04-2008 02:35 AM
10-03-2010 05:06 PM - edited 10-03-2010 05:11 PM
Yes you can load multiple instances.
Make sure each one has a different file name. You can do a wrapper for LoadLibrary which automatically makes a renamed copy of the dll - e.g. append the part number.
Then IN THE CALLING PROGRAM you declare all the routines that you get from the library (i.e. the ones you load using GetProcAddress(..) ) as __declspec( thread ).. This makes sure that each thread uses the routines from its own instance of the dll. Then there is no problem with collision of data - each thread is only using data from its own instance of the dll.
This works, I just used it with my own dll I wrote to do Direct2D drawing - needed to have a way to asynchronously do it in a worker thread to create an extra bitmap in the background and needed to be in a dll that's dynamically loaded to maintain compatibility with XP - and this ruled out possibility of using declspec(thread) in the dll variables - and TslAlloc was way too complicated for the particular use.
Anyway details don't matter main thing is, it works, and I tested it in a demanding environment where any collision between the thread data would cause an immediate crash almost certainly.
11-26-2014 04:32 PM
Someone written about doing a LoadLibrary wrapper. What that means? Is it in fact a dll wrapper of the original dll in which the handles to the original dll can be managed to output them to Labview?
Can someone clarify this for me , eventually to attach an example or a screen picture if it is handled in Labview only?
Thank you,
Virginia
12-01-2014 02:31 PM
Hi Virginia,
I don't know for sure what the previous posters may have been doing, but it sounds like they were creating a function or process that uses the LoadLibrary function and keeps a record of all DLL handles in use. Considering that the last post was made in 2010 and the original post was made in 2007, it might be better to create a new thread for your question.
12-08-2014 04:06 AM - edited 12-08-2014 04:07 AM
The idea as I understand it is something like this:
HANDLE MyLoadLibrary(LPSTR dllname) { // check in a global list if the DLL is already loaded // if it is // copy it to the temp directory with a different name and load it from there with LoadLibrary()
// else // LoadLibrary() the requested DLL // store the DLL name and handle in our global list // return the handle } void MyFreeLibrary(HANDLE handle) { // search the handle in our global list and remove the entry
// FreeLibrary(handle);
That all said it may work for a particular driver but more likely the driver will stumble somewhere over the fact that its functions expect to have exclusive control over certain lower level resources. It's definitely a sure way into maintenance nightmare and you should consider to use or create a different driver almost at all costs if possible at all.
