LabWindows/CVI
interfacing a camera
Is it possible to interface a camera in a LabWindows GUI? For instance using the frame grabber NI-PCIe-8236 with a Basler acA1300-30gm CCD ? Does it require additional drivers to be purchased or should IMAQ be sufficient?
Naba
(2,621 Views)
Hi nabs_nu,
If you are wanting to interface with a GigE camera via the PCIe-8236, you will need IMAQdx. If you have LabWindows/CVI installed, it should install support for C as well.
If you are just wanting to just display the picture, IMAQdx should be sufficient.
Brandon Grey
Certified LabVIEW Architect
(2,575 Views)
