02-25-2017 04:45 AM
Hello
I'm starting work in vision industry project
I want to know how can i integrate a usb camera into labwindows CVI
Thank you
02-27-2017 11:53 AM
Hi Em@na,
What specifically are you looking for? There isn't really an individual, "Getting Started" resource that I can point you towards, but more or less a collection of sources. Will you be doing any soft of image processing in your application, or simply image acquisition? If it's simply acquisition, you will need to install NI Vision Acquisition Software (VAS), which is the driver set for image acquisition functions. On top of that, depending on the type of camera you are working with, you may require a license for the software (IMAQdx, the driver from VAS for GigE, FireWire, USB 2.0, and USB 3.0 requires a license). If you will be doing both acquisition and image processing, in addition to VAS, you will need to have the Vision Development Module (VDM) which also requires a license. You can find more information about the difference in our Vision software here:
What is the Difference Between NI Vision Acquisition Software, NI Vision Builder, and the NI Vision Development Module?
http://digital.ni.com/public.nsf/allkb/45A5682F377996BB862572B50072787F
Licensing National Instruments Vision Software
http://digital.ni.com/public.nsf/allkb/F1699570F78FECBB86256B5200665134#VDMDDL
What Is the Difference Between NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O?
http://digital.ni.com/public.nsf/allkb/0564022DAFF513D2862579490057D42E
Since you are working with a USB camera and CVI, these may be a good resource before getting started in CVI:
Can't Find IMAQdx Library in CVI:
https://forums.ni.com/t5/LabWindows-CVI/IMAQdx-Library/td-p/755655
Getting Started with USB3 Vision Cameras and NI Vision Acquisition Software
http://www.ni.com/tutorial/14423/en/
Peter George
