09-05-2013 09:45 AM
Hello
I developed an application that uses a graphical interface as input interface
the program executable mode works properly,
I created the project dll and I tried to use the language (MTL)
I managed to read the function and executed (by proving popup msg) but the problem I can not launch the GUI "graphical interface" , I think we should integrate. "uir" but I have not found means
you find attached the error msg when called, who can help me please
09-05-2013 10:25 AM
this is the msg type
Error in call to LoadPanel
Parent PanelHandle: 0
UIR file name:"interface d'identification.uir"
Panel Resource ID: 1
Error Code: -94
File not found
juste for information
"interface d'identification.uir" it'ss my GUI that i need to load
09-05-2013 11:58 PM - edited 09-05-2013 11:58 PM
You are probably running into the probelem described into this KnowledgeBase entry.
09-06-2013 05:36 AM
Hello
thankyou so much i resolve the probleme 🙂
09-06-2013 06:02 AM
You're welcome!
