05-10-2013 01:00 PM - edited 05-10-2013 01:01 PM
Any thoughts as to why imaqopenAVI() may hang? I'm having a problem where an application is hanging on this function call on a deployed PC. The PC is running Windows 7 32-bit, Vision 2011-03 (updated to 2012-08 with no change). Same application running different PCs (XP, Win 7 32-bit, Win 7 64-bit) seems to be able to open the same .avi file just fine. The application was built using CVI 2012, on Windows XP, with NI-IMAQ 4.3 installed. The .avi file was generated using the NI imaq functions. I'm assuming it's some configuration problem or similar? Thanks.
Solved! Go to Solution.
05-10-2013 04:11 PM
I figured it out. It ended up being a problem with ffdshow on the target computer. All is good now!
