LabWindows/CVI
iam using PCI6035E and PCI6703 for data acquisition applications in my program in LABWINDOWS.Can u help me in the initialization part of the DAQ? what is the port address of the DAQ card? where can i find the initialization procedures for DAQ cards?
detailed description is not given in DAQ help.READ and WRITE commands are given,but where can i get the port address of the DAQ cards? where should i refer to know in detail about DAQ cards?
(2,390 Views)
What do you mean by port address? Do you mean the base address of the hardware? If so, you can use the Get_DAQ_Device_Info function to get the assigned base address of each device.
There are many example programs that are installed with LabWindows that I would suggest to look at. They are located within the ...\Program Files\National Instruments\MeasurementStudio\CVI\samples\daq directory. I hope this helps.
Todd D.
(2,390 Views)
