LabWindows/CVI
i want continues touch im using EVENT_COMMIT but not succeed
Please Help me out this.
in my application i did two button UP and DOWN.
if i press UP button my object will move up direction same if i press DOWN my object will move down.
if i remove finger from UP button my moving object should stop.
which event i shoul use,iam using lab window cvi 5.5.
P.S Attached snap shot
thank you
(3,687 Views)
Touch events are mouse events, so "touch start" should be EVENT_LEFT_CLICK, "touch release" could be EVENT_COMMIT - unless the control is an indicator.
But this old CVI might be missing EVENT_MOUSE_POINTER_MOVE to detect if the "touch point" moves outside of the control.
You'll have to look for a Windows API alternative to poll the pointer position and compare it with the control coordinates.
Sorry, can't help you more.
/* Nothing past this point should fail if the code is working as intended */
(3,667 Views)
