You can use a timer control.
Look at the CVI help topic "Programming with Timer Controls" and the timer.prj sample project.
Set the timer interval (ATTR_INTERVAL) based on user input using SetCtrlAttribute.
In a callback function for the timer, on EVENT_TIMER_TICK, set a global true, e.g. bStopFunction = 1.
In each function (or in the loop that calls the function), check the global, bStopFunction. If bStopFunction is true, gracefully end the function (or loop). If the continuous run is not programmed by a loop, you need to periodically check the global.
When the user presses the command button, set the bStopFunction global false (bStopFunction = 0), call ResetTimer() and SetCtrlAttribute to enable the timer (ATTR_ENABLED). Then start your (continuous) function.
