Hello roboo77,
I�m assuming you are using either the DIO-32F or DIO-32HS, since only these boards support group output. If this is the case, try using the DIG_Out_Grp function instead of DIG_Out_Prt. If you are not using either of these boards, groups are not supported, and you probably only need to output the bottom eight bits (to the bottom eight output lines). In this case, leave the top 24 bits as 0 (use only 0x00000000 to 0x000000ff) and it should work. If neither of these suggestions help, let me know what card you are using, what ports (lines) you want to write to, and I�ll look into it further.
Have a nice day!
Robert M
Robert Mortensen
Software Engineer
