LabWindows/CVI
how to group radio buttons in LabWindows/CVI
Hi Vishnu,
Jared project relies on a new feature of CVI 2010, the ability to create arrays of controls; this feature is not present in CVI 2009: you should have received a warning when opening the project since the UIR file format is newer than the IDE you are using.
Attached is a sample project that creates a group out of a series of radio buttons and handles it allowing multiple selection or no selection at all depending on two check boxes on the panel. It's a CVI8.5 project so you will have no problems in using it in CVI2009.
Message 11 of 15
(1,178 Views)
oops... mistakenly posted...
NickB
Message 12 of 15
(1,169 Views)
Hi Roberto,
    Thank you very much. This is the solution of my problem.
Actually with "ATTR_RADIO_SIBLING_ALWAYS_MARKED"  , some time it is working fine and some time not working properly.  But Radio button array works fine.
 "ATTR_RADIO_SIBLING_ALWAYS_MARKED" Should also work but I don't know why it is not working with me. Might be  i have mistake with using this.
--Vishnu
Message 13 of 15
(1,151 Views)
I found Radio button groups today. Very nice.
I was wondering a minor aspect, can I spread the buttons out a little so there is a little more space between each row?
Message 14 of 15
(635 Views)
You can use the flexible radio button group instrument driver instead, see here
Message 15 of 15
(627 Views)
