I write/read .ini file through WinAPI WritePrivateProfileString/ReadPrivateProfileString,now i want to delete a key from .ini,how can i do? thanks for any help?
To manipulate ini files, you can use the functions provided in the ini toolbox for CVI. Check out the example under ..\CVI\samples\toolbox\ini.prj. It shows you how do to the various operations and it alot easier to use than the WIN API
